August 21, 2019, 03:16:59 PM
Pages: 1 ... 9 10 [11] Go Down
Author Topic: Runners Build Thread  (Read 18224 times)
« Reply #150 on: January 28, 2019, 09:30:18 PM »
I installed the Currie Antirock this past weekend.  It's a very easy job and uses a torsion bar in place of the factory bar.  The most difficult part of the install was getting the inserts into the front frame tube.  Beveling the edges on the inserts, and using grease, makes the job much easier.  I took the Jeep out for a test drive and couldn't tell any difference in the ride.  Admittedly, I didn't take it into corners, so we'll see how that goes later.
Before
After
« Reply #151 on: March 17, 2019, 11:49:43 AM »
I gave the the LJ a little attention today.  Installed some Metalcloak bling (hopefully functional), in the form of their vented fender panels. Since I have an intermittent locker pump issue, I also installed a new set of front and rear air pumps.
Before
After
New Locker Pumps
« Reply #152 on: April 19, 2019, 02:52:12 PM »
Started the annual maintenance on the Jeep, to include:
 - Oil and filter replaced
 - Air filter replaced
 - Suspension and drive shafts greased
 - Front hubs disassembled, two bad inner seals replaced, and bearings repacked with grease
 - All brakes disassembled and cleaned
 - A rear sticking caliper replaced, along with new pads on the rear
 - Cleaned and repainted the frame and underside of the Jeep
I also pulled the 17" Walker Evans beadlocks and 35" Mickey Thompson MTs. They were replaced with a set of 17" Indy 1st generation Bronco wheels, with 35" Duratrac tires for everyday driving. For reference, the Walker Evans beadlocks and Mickey Thompson tires weigh 107.6 lbs each.  The Indy wheels and Duratracs weigh 87.4 lbs. The 20 lb per tire difference is noticeable when driving around.   This also gave me my first major Jeep Bling!
« Last Edit: April 19, 2019, 02:55:58 PM by Runner »
« Reply #153 on: May 20, 2019, 07:17:55 AM »
After having this in the garage for a long time I finally got around to installing the HealTech speedometer calibrator from Blue Monkey Motor sports.  The calibrator plugs into the factory harness for all 97 - 06 TJ and LJs, including either the 231 or 241OR transfer case.
http://www.bluemonkeymotorsports.com/products_ht.html
The installation was literally this simple:
 - Take the SPEEDOHEALER out of the package
 - Unplug the speedometer wire that goes into the transfer case
 - Plug the SPEEDOHEALER into the transfer case
 - Plug the factory wire into the SPEEDOHEALER pigtail
 - Run the wire over the transfer case and up near the firewall (battery side)
 - Follow the simple programming on the well written instructions
 - Zip tie the SPEEDOHEALER wherever you want it to be
 - Close hood and test drive
Note #1:  Before doing the install make sure that you note, using a GPS, the speed that the speedometer is reading when your actual (i.e. real) speed is 60 MPH.  Once you've done this you look up reading from your speedometer on the chart they provide.  For example, my speedometer read 70 MPH, while my GPS said the actual speed was 60 MPH.  I looked up 70 MPH on the chart, which gave me the "correction value" of 14.3%.  I entered this number into the control unit and it worked perfect.
http://www.bluemonkeymotorsports.com/downloads/SHV4A_User_Guide.pdf
Note #2: The display on the SPEEDOHEALER control unit, pictured, only shows one number at a time, so you would then have to enter the correction factor in one number at a time.  In my case, 1, then 4, then 3, giving me the needed 14.3% correction
Final Note: The entire install took me 30 minutes from start to finish.  This included adding split loom tubing on the entire length of wire provided by HealTech.  It also included more time than normal for running the wire from the transfer case to the firewall.  It was more difficult in my case, because I have a 241OR case and ultra tummy tuck.  This resulted in me not having much room to easily access running the wire.  The total cost was $120 (I think it's more now!), plus a few feet of 3/8" wire loom tubing.
« Last Edit: May 20, 2019, 07:29:13 AM by Runner »
« Reply #154 on: June 16, 2019, 09:44:43 PM »
I spent several hours Saturday, thanks to my best friend, installing:
- a like new factory exhaust I picked up from cwkann (several years ago)
- extended brake lines from mojojeep
- Nth Degree Dana 44 skid from Sarkis
The skid was definitely used, but the price was right and it only required some grinding and painting to get it back in shape.  They stopped making these and I've been looking for one for awhile. The big plus for it is that it protects the yoke from getting hit and there's no loss of ground clearance.
« Reply #155 on: June 17, 2019, 06:40:00 AM »
You brought that skid back to life. Looks fantastic!!
Sarkis
2000 TJ SE
« Reply #156 on: June 30, 2019, 09:42:35 AM »
I spent four days at Rausch last week and added a few more battle scars to the Jeep.  In spite of two straight days of rain, it was a good time!.
« Reply #157 on: August 18, 2019, 01:26:09 PM »
Replaced a smaller plate and fin transmission cooler with a heavy duty B&M 70264 stacked plate cooler.  I also have a new transmission pan, with drain plug, and a transmission temperature gauge that will get installed at some point.
« Reply #158 on: August 18, 2019, 01:35:52 PM »
On my last wheeling trip I kept hearing some clunking noises and the rear suspension didn't seem to be working right.  When I got back home I inspected the rear and discovered one of my 6Pak shocks was leaking badly and both were bent.  I'm not even sure what happened, but I sent them back to Metalcloak to be rebuilt.  I'll have to be careful on the reinstall, so I don't have a repeat issue.
Pages: 1 ... 9 10 [11] Go Up
