September 20, 2019, 02:01:50 PM
Pages: 1 2 [3] Go Down
Author Topic: Serenity 2.0 Build  (Read 7815 times)
Dynamic
« Reply #30 on: April 18, 2018, 07:41:48 PM »
ARB Twin OBA
 Installed (What a PITA that was)  Initially tried the under hood mount but the hard-lines are moved and basically make this impossible without major modification, decided to go with the TeraFlex under seat mount. Was planning on CMM because i have several of their products but their mount does not allow for the Air Manifold Kit.  Got that wired up and tested Love this mod being able to air up quickly and effiencetly was awesome i was able to do mine and 2 others so much faster than previously
Carolina Metal Masters Grab Bar w/Ram ball Mount
Customized with jeep name and slogan, love this mount i have tested it with a phone and a larger tablet testing with an iPad this coming weekend so far everything has been rock solid.  This is my 2nd Piece of CMM gear and everything is just such high quality Already planning to order the seat / accessory mount
PoisonSpyder HD Cross Member
Nothing to say here swapped the crap stock one for a solid thick steel one. Stock ones tend to bend and dent And then warp your skids. So it was easier to swap out now and have peace of mind. Wish i had a better pic its significantly beefier than stock
Ace SKids:
PITA to install DO NOT recommend to anyone! That said there was no way the front skid was going to fit with the exhaust modifications that were done (Pipe bends below Driveshaft to provide clearance... Soo UPGRADES.  But the skids are now installed so thats a thing
Heres the old problem i ran into that leads to our next update
Needed a shop more local than ORI for some of these small things i couldn't handle so I reached out to Colin @ Quality Performance Group. To get the Y-Pipe and Driveshaft
aFe Twisted Steel Y-Pipe
Decided this was probably my best long-term fix since it fixed my immediate Problem (Crossover to low)  and provided a significant upgrade in clearance for the front driveshaft.  It relocates the crossover behind the Crossmember and in front of the transfer case while also keeping it out of the way of the long arms.
And the new clearance
When i stopped by QPG  to discuss ordering the pipe and install we took a look at the problem and discussed the option of also adding a Driveshaft And my stock being at such an extreme angle sitting in place.  Went ahead and ordered an Adams Drive shaft while the skids were going to be down and before the xover pipe was installed in the way
Adams 1310 Front Extreme Duty Series
Front only for now as mentioned in talking with Colin@QPG  it made sense to do it now while it was easier to access with everything apart and i was really not comfortable with the angle of the stock shaft
This is the angle the stock DriveShaft was at sitting level on flat ground  Duh
Next up Is Summer Conversion! Trektop NX Glide and a ALienSunshade sitting in my living room waiting to go on this weekend.
2011 JKU Rubicon Project "Serenity" -> SOLD
2017 JKU Rubicon Recon Serenity 2.0
« Reply #31 on: April 19, 2018, 06:37:37 AM »
Gonna love the Adams drive shaft. Did both front and rear on R3.
I love the look of those wheels!
« Last Edit: April 19, 2018, 06:56:03 AM by VA6489 »
Dynamic
« Reply #32 on: April 21, 2018, 09:14:51 PM »
Besttop NX Glide
AlienSunshade
EVO Evap Skid
Posted from somewhere in the verse
« Last Edit: April 22, 2018, 11:02:15 AM by Dynamic »
Dynamic
« Reply #33 on: April 21, 2018, 09:17:34 PM »
After checking all the bolts and working on jeeps for the day.  We got out and tested the flex very happy with the TF setup.  And i still had more room to go but i was sitting on top of the 37s
« Last Edit: April 22, 2018, 06:38:38 AM by Dynamic »
Dynamic
« Reply #34 on: April 29, 2018, 04:59:50 PM »
Some pics from icebreakers
« Reply #35 on: April 30, 2018, 08:35:35 AM »
Enjoying the transfermation on your build. Look forward to seeing it in person at Rausch.  Thumbs Up
Dynamic
« Reply #36 on: July 12, 2018, 07:41:31 PM »
Wheeled at the cove with friends at the last big dogs event good fun! But 2nd pic V-Trail was a mess and it down poured after being clear for hours about halfway up had a rock slide out brought the jeep down at a bad angle bent a rear axle shaft flange.
New chromolys ordered via ManassasOffroad from CarbonOffroad got to get those in asap before back to back wheeling camp heep and big dogs
« Last Edit: July 13, 2018, 01:51:50 PM by Dynamic »
« Reply #37 on: July 17, 2018, 09:35:00 PM »
AlienSunshade
My SpiderWebShade is starting to wear thin.  Was looking at Alien.  How do you like it?
Big Mike - 2012 JKU Crush, 2.5" Teraflex Lift with Shocks, JKS Quick Discos, RockHard4x4 Skids and Evap Relocation Bracket, JCR Crusader Bumpers (mid-width front, mid-width rear), Teraflex HD hinge tire carrier, SmittyBilt h2o winch, 16x8 ATX wheels with 315-75-16 General Grabber AT2's.
Dynamic
« Reply #38 on: July 17, 2018, 10:04:41 PM »
AlienSunshade
IMO the label on the back saying aliensunshade is the only difference having had both
Pages: 1 2 [3] Go Up
