September 16, 2019, 08:45:39 PM
Pages: 1 ... 7 8 [9] 10 11 Go Down
Author Topic: RRR  (Read 17975 times)
0 Members and 3 Guests are viewing this topic.
« Reply #120 on: March 19, 2019, 07:51:45 AM »
His comment was that the  D60 while a great axle  the pinion would not be strong enough to handle the huge torque load of the 10:1 reduction from the Atlas.... Anyone in the market for a Kidney?  Ok  just kidding  for the treadlightly approach I have the  current uprated 44s will do.
This is one I had not heard.  I run a Advance Adapter Rubicrawler on my LJ, with twin sticks, This gives me four crawl ratios:
-1:1
-2.72
-4:1
-10.88:1
My axles are dana 44 front and rear.  You definitely need to be careful at 10.88:1, but I've had no issues thus far.  The only real problem is you have to bump it out of gear to stop.  If you push on the brakes while at that ratio they won't stop the vehicle.  The good news is it will idle up a 45 degree incline.
« Reply #121 on: March 19, 2019, 11:50:16 AM »
-1:1
-2.72
-4:1
-10.88:1
From what Advanced  tells me the deep reduction  gearing  is not ment to take any kind of big HP, just idle or a bit above.  I bet you are running an automatic?  I can see the brakes being nearly useless  in the deep reduction.  The unit I am looking at is a
1:1
2.72:1
3.80:1
10.34:1
Advanced  dosent seem to have an issue with the 44 but would prefer a stronger  ring pinion... Like everything  it is all in how you use it.  Drive smart and the equipment will last a long time.
Love to see you rig in action
« Reply #122 on: March 19, 2019, 04:50:36 PM »
Something else with the chaos philosophy that I like is  they  build  in such a way that the engine is the weakest link.  That is to say  if the engine makes 500hp and 500 torques, the  drive line will handle 600/600.
This sounds like a great way to blow up your engine if you ask me. I'd rather break a $30 u joint then redline the engine and throw a rod if something goes wrong.
But I'm just a simple man in an LJ on 33s with no long arms and no truck night victory.
Sent from my SM-G930V using Tapatalk
« Reply #123 on: March 19, 2019, 05:50:19 PM »
James,
You missed the point. If the hardware behind the engine is stronger than what the engine can produce chances are you will not break that u joint... hence continue to wheel happy.
But then again  if you operate as stated doesn't matter how it is built...your going to break it.
Sent from my Moto Z (2) using Tapatalk
« Reply #124 on: March 19, 2019, 06:09:36 PM »
All I know is, at some point, something is going to break. I'd want the engine to be the last thing that breaks. I understand why they did it that way, I just have a philosophical difference on it.
If you hit a bump and mash the skinny pedal one time (which happens no matter how careful you are), I'd much rather replace an axle shaft or a u joint then the engine.
« Reply #125 on: March 19, 2019, 06:35:33 PM »
1:1
2.72:1
3.80:1
10.34:1
Definitely an automatic and I'm very conscious of cause and effect.  That said, the skinny pedal is treated respectfully and engine speed is kept to a minimum.
« Reply #126 on: March 19, 2019, 06:43:30 PM »
Amen.
« Reply #127 on: March 20, 2019, 10:59:19 AM »
Tweaking the shock timing today.... Interesting setup bit different from my motorcycles...will post some pictures a bit later
bigjimbo
« Reply #128 on: March 24, 2019, 03:16:36 PM »
Now you just need some tons!
2012 JKU - RIPP SC - 4" TERAFLEX
37X13.50R17 - TRAIL READY HD17
UD60s - ROCKHARD SKIDS - WARN10S
« Reply #129 on: March 25, 2019, 08:23:17 AM »
Jimbo!  Are you back state side !?!?
Build plan... include  Chaos Spec axles in the future and an atlas....  If this rig sells I have another build in the wings.... Killer Willy's wagon full on build with a Cummins 3.8 twin turbo.
But back to reality  No real pix yet. will post some tis week while I get under and service the joints and continue to set shocks.
bigjimbo
« Reply #130 on: March 26, 2019, 02:39:35 PM »
Not yet.  We won't be making EJS anymore either.
So you're swapping the suspension and possibly selling it?  I want that EVO kit....one day I'll get it.
« Reply #131 on: April 01, 2019, 08:04:08 AM »
Couple shock tuning runs.  Vid 1 at 20-22 mph.Vid 2 at 8-10mph.
Special thanks to the crew of Chaos off road park and Chaos Fab shop.
Cheershttp://cloud.tapatalk.com/s/5ca20c103892c/received_1739357746164008.mp4http://cloud.tapatalk.com/s/5ca20bff81be8/received_319313105449743.mp4
« Last Edit: April 01, 2019, 10:10:35 AM by R3 »
« Reply #132 on: April 01, 2019, 03:33:22 PM »
Some build pics
« Last Edit: April 02, 2019, 06:07:22 AM by R3 »
bigjimbo
« Reply #133 on: April 02, 2019, 01:36:43 PM »
Looks nice Rob!
« Reply #134 on: April 02, 2019, 01:59:52 PM »
Thank you sir
Sent a PM..
Pages: 1 ... 7 8 [9] 10 11 Go Up
