December 14, 2019, 12:23:53 AM
Pages: 1 ... 3 4 [5] Go Down
Author Topic: Aftermarket Fuel Injection  (Read 8548 times)
MusketStyle
Ramming it through... MusketStyle
« Reply #60 on: October 01, 2018, 08:53:49 PM »
More updates. Diode definitely worked, however I have narrowed down my lean out backfire to low fuel pressure. The Novak Adapter fuel pump is a 5/16 fuel line setup that is supposed to push 58 psi. Running only get to 38 psi. I suspect that I will need to go to 3/8 fuel line and a bigger pump.
Sent from my SAMSUNG-SM-G891A using Tapatalk
2002 WJ I6 selectrak, transmission shift kit
1985 CJ7 I6 258 4.2L
Dana 300
T-5 transmission
32x11.50x15
« Reply #61 on: October 02, 2018, 06:37:05 AM »
Smaller diameter line might need a high pressure pump to maintain the line pressure or go with a larger line and a higher volume pump.  It is a process and when it all is done you will be very happy with your rig.
« Reply #62 on: October 02, 2018, 09:05:13 AM »
To feed my AMC 258 I6 with the Mopar Performance MFI I needed to go to 3/8" fuel line with a 70-90 PSI; 40 gph pump and an adjustable fuel regulator set to 40 psi at idle (49 psi at zero vacuum). I did not change out the 5/16" fuel return line.
I realize I am running a very different system than you are - mine is a common rail, speed density, Multi-port Fuel Injection) on a smaller engine.... Anyway I offer this just as reference point.
Garner
MusketStyle
« Reply #63 on: February 10, 2019, 12:27:32 PM »
Diode fixed the shut-off problems. Had to remove and reinstall the distributor to get additional timing to solve the backfire. Running about 18* advance at idle.
Dana 300
T-5 transmission
32x11.50x15
Pages: 1 ... 3 4 [5] Go Up
Treasurer: Danille Wilson (TJ Girl) | Member-at-large: Brit Nora (rebel4sale)
