January 19, 2019, 09:25:43 PM
Author Topic: Possessed Jeep  (Read 860 times)
total2010
« on: February 10, 2018, 07:58:57 PM »
My 08 JKU has been possessed. Long story short, it was the TIPM which I did replace. Symptoms were (Wipers and washer fluid going crazy, horn blowing non-stop, Car running with no key in ignition, doors locking and unlocking rapidly with no control & headlights turning on and off) The Jeep went fine for about 10 months after the TIPM was replaced and now the same issue is back again  Crying I'm wondering if there's an issue with the wiring somewhere. Specially that I recently added some lights and LEDs a year ago. Last time the TIPM did the trick and there were no further issues. Now I'm worried that it'll happen again on the highway or somewhere where I can't control it. are there any common wires that go loose in the JK?? any loose grounds somewhere? The Jeep could shut off by itself which is very dangerous. Anybody knows a good shop that could look over the factory wiring for a good price? or any known wires that tend to go bad/break in the JKS ??
« Reply #1 on: February 10, 2018, 08:44:06 PM »
Did you ever put that tri-link in and do the 4wd conversion?
Seriously. Issues could come from that.
« Reply #2 on: February 11, 2018, 03:19:27 PM »
TIPM is/was a recall item for certain model year WK2 Jeep Grand Cherokees.  Lindsay screwed mine up doing the recall. It was fixed by another dealer since I specifically told them not to do that recall repair and they did it anyhow.
One of the many reasons I never went back to Lindsay and never recommend them.
« Reply #3 on: February 11, 2018, 05:54:26 PM »
Dammit, Again? Double check the main connections to the TIPM again... Did you put Dielectric on everything when you replaced it? Might just be some fresh corrosion on some of the connections, I hope this is something simple like that...
What kind of ranges are you typically seeing on the guage? The alternator isn't overcharging, is it?
total2010
« Reply #4 on: February 11, 2018, 07:24:20 PM »
Oh, the first time it happened was way before the conversion.  Confused  But yeah, I did do the conversion but ended up sticking with a stock Dana 30 front and kept my rear. Project 100% done and functional.
total2010
« Reply #5 on: February 11, 2018, 07:25:38 PM »
NEVER go to Lindsay, they're the worst. Unfortuantely, mine doesn't have a recall  Crying Jeep screwed me on that one
total2010
« Reply #6 on: February 11, 2018, 07:33:45 PM »
Yessir!! a little shorter than 10months and the same thing is happening again. I did check the main connections, everything was nice and tight. I took out the TIPM and sent it back for a replacement one...Hopefully that does it this time -_- I'm just curious, anyone had this problem before?
« Reply #7 on: February 12, 2018, 02:27:40 AM »
I've replaced the TIPM's on 2 chrysler vehicles I've owned, One JK (2008) and One Ram Pickup (2005)... Both at less than 80k miles... But past warranty, Didn't ever have to replace them again though...
schreiberaj
« Reply #8 on: February 12, 2018, 07:48:49 AM »
Sell it and get a TJ
