February 23, 2018, 10:55:32 PM
Author Topic: A shocking question...  (Read 241 times)
« on: February 13, 2018, 10:00:46 PM »
Bilstein or fox?
2014 Chevy Silverado. Z71 4wd. Almost 100k on the clock. The trucks spent a lot of time in Jersey and the rancho shocks are rusting out and showing the age. I wanna swap shocks but to who's? I run billstein on the jeep and have been pleased. No plans to lift it more then maybe level it if I get airbags for the rear. What say ye internet land? What do you run what models do you like? Please keep in mind I'm not doing coilovers all four corners...
« Reply #1 on: February 14, 2018, 07:28:23 AM »
Look on CL or the like for a new set of bilsteins that some one took off to put a lift on.
One man's trash is another man's treasure.
« Reply #2 on: February 14, 2018, 08:21:31 AM »
So you aren't swapping the entire strut in the front?
Bought the shocks and struts for my 2008 off of Amazon as some off-brand OEM replacement.  They're doing fine after 1000 miles.  I'll play the angel on your one shoulder and ask are you really sure you NEED some sort of upgraded shock?  I thought about the Bilstein 5100s when I went to replacement mine but rationalized that for the amount of time I spent towing my Jeep somewhere (roughly 2-3 trips/mo on average) that the OEM would be totally sufficient.  If you're worried about extra tongue weight support in the back or keeping your headlights level, maybe think about an air bag kit.  Come to think of it, I think a set of OEM shocks/struts + a Firestone kit = around the cost of a set of Bilsteins.
I have a leveling kit on mine, ~2" in the front, and have been very happy with the OEM setup.  I shall be your voice of reason.
Side note: front leveling kits for the Silverado are fun and cool until you need to replace your front shock/strut.  When you go to do that, the additional leveling puck that sits atop the strut doesn't allow enough room to just lift the strut out when you loosen things up.  In order to get enough droop and clearance to remove the strut (and install the new one with the puck), you end up having to also disconnect the upper control/"A" arm from the hub.  This is a PITA to do on your own because now the entire hub in is flopping/hanging by just the brake line unless you support it somehow.  Truck stuff is a lot heavier than Jeep stuff.
« Last Edit: February 14, 2018, 08:23:32 AM by Jeepsnbuses »
Jeep: 1987 Cherokee w/ 4.0, 242, D30/44, and some things
Jeep: 1986 CJ7 w/ 258, 5-speed ((SOLD))
DD: Thirsty 2008 Chevy Silverado
« Reply #3 on: February 14, 2018, 08:54:16 AM »
I have always had a good luck with Bilstein.  They are more durable and last longer than the OEM and can take lots of abuse.
« Reply #4 on: February 14, 2018, 09:14:41 AM »
rancho is the standard take off unfortunately.
« Reply #5 on: February 14, 2018, 09:16:31 AM »
haven't figured out if i'm swapping the entire strut or not yet, kinda why I made this. I don't need something super amazing duperty dooo. but I towed almost every weekend last spring, and having a better shock that's not rusting out like my current ones would be well beneficial. I've thought of air bags and or helper bags in the rear, just haven't gone down that rabbit hole yet.
« Reply #6 on: February 14, 2018, 10:44:04 AM »
Having just done this myself, I would say swap the entire front strut while you're down there.  Then you'll be good to go for another xx,xxx miles.  I honestly don't think Bilsteins would make any real noticeable difference, though.
« Reply #7 on: February 14, 2018, 10:50:12 AM »
well fox makes a nice strut system... and the rear shocks are nice from them too... hmmm
« Reply #8 on: February 14, 2018, 12:14:09 PM »
https://www.amazon.com/Fox-Performance-2007-2016-Chevrolet-Silverado/dp/B01I2V3XHK/ref=sr_1_2?ie=UTF8&qid=1518628281&sr=8-2&keywords=980-24-660
https://www.amazon.com/Fox-985-02-018-Performance-Coil-Over-Shock/dp/B01GRWTU32/ref=sr_1_1?s=automotive&ie=UTF8&qid=1518628314&sr=1-1&keywords=985-02-018
Or.
https://www.amazon.com/Bilstein-33-238319-Shock-Absorber/dp/B00T369HRY/ref=sr_1_2?ie=UTF8&qid=1518628385&sr=8-2&keywords=2014+silverado+bilstein+5100
https://www.amazon.com/Bilstein-24-238304-24238304-Shock-Absorber/dp/B00T367RUS/ref=sr_1_1?ie=UTF8&qid=1518628385&sr=8-1&keywords=2014+silverado+bilstein+5100
Unless yall are finding stuff I'm not. then please post links!
and No. I'm not doing the brand new falcons. WAAAAAYYYY to expensive
« Reply #9 on: February 14, 2018, 12:37:35 PM »
Let me rephrase that. Way to expensive to not split the purchase up which is the plan
« Reply #10 on: February 18, 2018, 07:10:19 AM »
?????  Should be fine. But I don't recommend installing new shocks on the front or rear and running them with the old shocks since it can cause all kinds of interesting handling problems.
President: Jeremy Long (JK_HVGC) | Vice President: John Davis (jdavis2nd) | Secretary: James Wesolek (sirjames186)
Jason Markvart (LNDSRK) | Steve Scott (Islander90) | Josh Storer (Jastor)| Mike Finelli (BiggMike) | John Harper (Opie)
All images from NoVaJeepers.net are exclusive to the Northern Virginia Jeepers Association. Any reproduction of exclusive Northern Virginia Jeepers Association material is strictly prohibited without written consent of the Northern Virginia Jeepers Association. Jeep®, Wrangler, Cherokee, Commander, Compass, Patriot, Liberty, Unlimited, Rubicon, SRT, HEMI and Grand Cherokee are copyrighted and trademarked to Chrysler LLC. NoVaJeepers.com, Northern Virginia Jeepers Association is not in any way associated with the Chrysler LLC.
Materials are copyright Northern Virginia Jeepers Association 2002-2011.
