February 18, 2019, 04:20:10 PM
Pages: 1 ... 5 6 [7] 8 9 ... 16 Go Down
Author Topic: The Silver Bullet - resurrection of a TJ  (Read 11944 times)
« Reply #90 on: April 07, 2018, 06:44:08 AM »
It really IS looking better every time. Canít wait to see it on the road.
Davetopay
« Reply #91 on: April 07, 2018, 09:19:55 AM »
I think I saw a thing, but I don't know what thing I thought I saw.
« Reply #92 on: April 07, 2018, 12:12:51 PM »
Think Iíve figured out my front driveshaft situation. I couldíve sworn that the threads for the front driveshaft U-joint straps was 1/4-28. I was using my handy dandy Matco tap and die kit but the 1/4-28 tap just wasnít doing it. It would thread through and kinda-sorta felt like it was doing its job, but I would end up encountering more resistance than I was comfortable with when I went to try and thread the bolt it after it. I broke a strap bolt off in a yoke on my XJ a couple years ago and it really wasnít a fun experience...makes me overly cautious now. Probably a good thing.
Got fed up and thought maybe my taps were worn, and I think I was right. Went to Advance and confirmed that the bolt is definitely 100% a 1/4-28 thread. The bolt threaded into the sampler holes at the store like butter, but the tap just sort of slipped in and wasnít grabbing. Guess itís been used well. Unfortunately Advance, Autozone, Pep Boys, and Home Depot all donít carry a 1/4-28 tap. They each have 1/4-20, then jump to 5/16-18. I really, really didnít want to have to drill and re-thread the yoke. NAPA to the rescue! Ordered a $3.49 1/4-28 tap, and paid $11 extra for a tap driver. Should be here in an hour-ish and hopefully Iíll be good to go.
In the meantime, replaced the battery lead ends, replaced the spark plugs, and drained/filled front and rear diffs. Also was a bit bummed to see that my passenger rear brake appears to be leaking fluid. Hopefully just the wheel cylinder. Another fix for another day.
« Reply #93 on: April 07, 2018, 04:20:35 PM »
Hit a bit of a roadblock with the whole wheel cylinder thing.  It was a bit more than the wheel cylinder...
After defeating 7 years of rust that held the drum on, I found a total mess on the inside. Several bits and pieces of hardware rolling around freely inside the drum, and the shoes were toast...looked like a rock or something had torn up the liner.  After pulling everything off I found a severely jacked-up wheel cylinder.
I'm not quite sure how something like this would happen.  Are the backing plates for these TJ brakes normally bent a little bit like this one?  It looks like some sort of obstruction or damage caused the wheel cylinder to be pressed in and clocked towards the front of the Jeep.  It's a bit tricky to see but in the pic below is the back of the bent backing plate...
And this is the opposite side, which looks to me like it's correct.
In the image of the bent plate, the wheel cylinder mounting bolt on the right is actually pressed in so far and in such a way that I can't get a socket on the head of the bolt.  Anyone ever seen this before?  Any suggestions on solutions?  I figure I have the following options:
A) Try to manhandle and bend the backing plate back into the position it should be in.  No guarantees that I'll gain access to the head of that one bolt, and I also think this would make re-installing the drum hardware more difficult depending on where mounting holes end up.  Would be imprecise.
B) Replace the backing plate.  I need to service the D35 anyways so this wouldn't be terribly difficult.  Plus the backing plate mounting nuts look clean, rust-free, and ready to come off.  Anyone know where I could find one?  Doesn't seem to have a part number, may need to find some used part on eBay or the forums.
C) Remove the backing plate setup altogether and do a disc brake conversion???
« Reply #94 on: April 07, 2018, 04:43:31 PM »
I'd go option C, but if you need it I've got a drum rebuild kit around here somewhere I'll toss in for you tomorrow.
« Reply #95 on: April 07, 2018, 06:21:16 PM »
Some initial research has me leaning towards sticking with the drums for now so I may take you up on that offer.
« Reply #96 on: April 07, 2018, 06:32:25 PM »
With a rear 35. Fix it for now and save to do an 8.8 or rear 44 with disk brakes. It's stupid how expensive it is to do disks on a 35.
« Reply #97 on: April 07, 2018, 08:14:41 PM »
I like this idea. Seems like the cost wouldnít be super exorbitant unless Iím buying a custom manufactured kit, but I donít think the extra effort would be worth it for something that will get tossed in the next year or two.
« Reply #98 on: April 07, 2018, 10:27:44 PM »
Scott has a rear 44. 3.73 gears $800 with brakes. Cheapest kit I've found for the conversion is $600 plus labor..... $200 means I don't need after market axle shafts for a long freaking while
« Reply #99 on: April 08, 2018, 10:58:17 PM »
$600 for the conversion kit sounds about right based on what I found online. It looked like the easier/cheaper option would actually be to pull the dust shield and hardware from a D35 ZJ and move it over. Direct fit, but I think more effort than I want to put in for a C-clip 35 that wonít be around forever.
Iím down in NC for work and think I have a guy nearby who will sell me a pair of D35 dust shields for $50. Unless I come across a better deal in the next day or two Iíll buy those, clean and replace the other brake hardware, install new shoes and drums, and be done with it.
« Reply #100 on: April 09, 2018, 06:23:01 AM »
I have a brand new master cylinder for a D35 if you need it.  I swapped to an 8.8 so I will never it.  I'm in Lorton.  Swing by on your way home.  I'm just off I-95.
« Reply #101 on: April 09, 2018, 06:48:00 AM »
A brand new wheel cylinder?  Just the one?  I will take whatever D35 hardware I can get.  I've gotten over feeling any sort of guilt for taking this stuff off people's hands because it would just be collecting dust forever, otherwise.
« Reply #102 on: April 09, 2018, 07:01:52 AM »
I've got a whole D35 out of a 98TJ, complete drum to drum, with 3.73 gears, sitting in my shop, nothing wrong with it. Feel free to come take it away!
« Reply #103 on: April 09, 2018, 07:07:53 AM »
Alright, PM'd.
« Reply #104 on: April 09, 2018, 07:08:31 AM »
Yes, free cylinder if you want.  Looks like Zuke's got a great offer for you too.
Pages: 1 ... 5 6 [7] 8 9 ... 16 Go Up
