January 17, 2019, 11:42:51 AM
Author Topic: Wheel Alignment - Does this camber look right??  (Read 1765 times)
unleashd
« on: April 03, 2018, 11:22:09 AM »
Just noticed that the camber on the front looks deceivingly incorrect to the eye. Is it just my bad eyesight?
KN4MAT
2004 Jeep Wrangler Sport
« Reply #1 on: April 03, 2018, 11:24:40 AM »
I bet you need ball joints. Jack it up and see if the wheel moves when you push and pull on the top. I had to replace the driver side ball joints in my Daughters before I drove it home from FL. It was doing the same. They can also induce death wobble.
Redleg
« Reply #2 on: April 03, 2018, 11:30:50 AM »
If its not the ball joints, you might want to get a laser on the axle, it could be bent, but I agree it is probably the ball joints.
Bill
schreiberaj
« Reply #3 on: April 03, 2018, 01:12:02 PM »
If it drives straight, and doesn't get bad vibrations or death wobble then just run it. It's cool nowadays to have messed up camber anyways.
« Reply #4 on: April 03, 2018, 01:19:27 PM »
In a whispering voice: "No one wants to mention that it might be the axle's "C" bent do we?"
Redleg
« Reply #5 on: April 03, 2018, 01:33:07 PM »
Well there is that....
Bill
« Reply #6 on: April 03, 2018, 01:41:16 PM »
#jeepstancelyfe
« Reply #7 on: April 03, 2018, 02:01:58 PM »
If this is true (hope it's not) I've got another d30 with 3.73s and fresh ball joints for sale
unleashd
« Reply #8 on: April 03, 2018, 03:06:00 PM »
Vibes went away after I installed the transfer case lowering kit. Drives straight with no wobble. I think I am just ADD about the visual Very Happy
KN4MAT
unleashd
« Reply #9 on: April 03, 2018, 03:08:25 PM »
I have 3.07 Sad
KN4MAT
wbsjp
« Reply #10 on: April 03, 2018, 03:52:53 PM »
Its NOT a JK....... Toe may be out.......
Wayne
  AARP,NAXJA,NRA Endowment member
"the cost of Freedom isn,t Free"
« Reply #11 on: April 03, 2018, 06:17:46 PM »
Agree, Looks to me like the toe is pointing in.... Set each wheel individually to straight ahead and see if the camber still looks crazy...
« Reply #12 on: April 03, 2018, 09:16:46 PM »
I have 3.07 Sad
I'm impressed you'r plate is still legible.
unleashd
« Reply #13 on: April 03, 2018, 10:02:58 PM »
Checklist
- Check Ball Joints
- Check if the Axle may be bent??
- Check if the 'C' - Knuckle is bent
- Check for 'toe in'
KN4MAT
tomjones20194
« Reply #14 on: April 04, 2018, 12:59:03 PM »
Camber cannot be adjusted. It fixed at the steering knuckle. If itís out of spec then worn ball joints, bent knuckle or bent axle.
1979 CJ-5 Renegade Levi Edition (360 V8)
2008 Wrangler Unlimited Rubicon
