January 17, 2019, 11:57:30 AM
Pages: 1 [2] Go Down
Author Topic: Wheel Alignment - Does this camber look right??  (Read 1769 times)
unleashd
« Reply #15 on: June 04, 2018, 10:52:21 AM »
Any suggestions for brand/specs of the ball joints? I was talking to Exline earlier today, and he mentioned that I should look at adjustable ball joints.
KN4MAT
2004 Jeep Wrangler Sport
« Reply #16 on: June 04, 2018, 11:10:22 AM »
That is all up to you. If you have bad return to center issues then adjustable may be the ticket, MOOG does make them but they are not cheap.
I am putting MOOG, non-adjustables in the Daughters TJ this weekend. They are good quality and expensive enough.
At Advance:
Standard MOOG Upper K3134T --$68.99
Standard MOOG Lower K3161T --$78.99
The caster correction joints are available 1/2' thru 2' caster correction and are around $104 to $150 each.
« Reply #17 on: June 04, 2018, 11:13:16 AM »
Camber cannot be adjusted. It fixed at the steering knuckle. If itís out of spec then worn ball joints, bent knuckle or bent axle.
About that, They came out with offset ball joints to give the ability to do that now Shocked (see above)
unleashd
« Reply #18 on: June 04, 2018, 12:53:35 PM »
At Advance:
Is that price per ball joint? or a set of 2? Amazon has the same for less than half the price for each.
Upper - https://www.amazon.com/Moog-K3134T-Ball-Joint/dp/B000C542NY/ref=sr_1_4?s=automotive&ie=UTF8&qid=1528134529&sr=1-4&keywords=moog+k3134t+ball+joint
Lower - https://www.amazon.com/Moog-K3161T-Ball-Joint/dp/B000C55Y54/ref=sr_1_4?s=automotive&ie=UTF8&qid=1528134710&sr=1-4&keywords=moog+k3161t+ball+joint
KN4MAT
« Reply #19 on: June 04, 2018, 01:13:28 PM »
That was advance. Wow didn't know that amazon sold them
unleashd
« Reply #20 on: June 04, 2018, 01:20:08 PM »
KN4MAT
wbsjp
« Reply #21 on: June 04, 2018, 09:38:53 PM »
Dana/Spicer,greasable .Moog  (some are )knurled and will mess up the holes in the knuckle.
 About the adjustable joints...did they tell you how much you need ?
Wayne
  AARP,NAXJA,NRA Endowment member
"the cost of Freedom isn,t Free"
unleashd
« Reply #22 on: June 05, 2018, 05:22:11 AM »
No. I spoke to them on the phone while trying to get a service appointment. He also said that they wonít install those.
KN4MAT
« Reply #23 on: June 07, 2018, 06:14:08 AM »
Adjustable ball joints aren't needed and don't typically hold up as well as factory ones, so stick with Spicer or Moog.  As has been said, camber can be impacted by:
- bent axle tubes
- bent knuckles
- worn ball-joints
The only other thing I can think of would be a bad hub bearing (I once had one with excessive play that gave me fits).  Lastly, stay away from knurled ball-joints.  I know this from my own bad experience with them!  FWIW, I have a personal preference for Spicer, since that's what was on there from the factory and I've seen them last 200k+ on stock tires.
https://www.amazon.com/Spicer-706944X-Socket-Assembly/dp/B007N6OHI0/ref=sr_1_1?s=automotive&ie=UTF8&qid=1528368922&vehicle=2003-42-356-141--30-1-8-3360-254-1-2--83-1-0&sr=1-1&ymm=2003%3Ajeep%3Awrangler&keywords=spicer+ball+joint
unleashd
« Reply #24 on: June 07, 2018, 10:19:41 AM »
These are what received last night from Amazon. They are Moog. I have used Moog suspension parts multiple times in the past on other vehicles with good results. So, I stuck to that brand. Should I return them to get the Spicer instead?
KN4MAT
« Reply #25 on: June 07, 2018, 02:31:30 PM »
These look like Moog Problem Solver ball joints and are knurled, i.e. notice the splines.  I would not use these unless absolutely necessary (they will enlarge the hole and you can't go back to smooth ones).  Stick with a smooth bore ball joint like the one pictured in the link.
https://www.amazon.com/Spicer-706944X-Socket-Assembly/dp/B007N6OHI0/ref=sr_1_fkmr0_1?s=automotive&ie=UTF8&qid=1528399591&sr=1-1-fkmr0&keywords=spicer+ball+joint+wrangler+tj
Bottom line, you can use a Moog one if you want, but try to stay away from knurled versions.
Update:  My statement above assumes the ball joints haven't been replaced before with knurled versions.  If it has, then you will have no choice but to use what you already bought.
« Last Edit: June 07, 2018, 02:38:33 PM by Runner »
nosigma
« Reply #26 on: June 07, 2018, 11:38:47 PM »
Take it to a good shop and get it aligned.    The alignment sheet will tell you exactly what is out of spec if anything.  Just looking at a picture to try and decide if something is bent (camber) or the toe is off is guess work.  If you dont know how to check ball joints have them do it while you are there.  Once you have numbers you will have answers.
« Last Edit: June 13, 2018, 10:03:05 PM by nosigma »
VirginiaZJ "Frank, Stop. Don't come down here"
Somebody: "Is John in a predicament?"
VirginiaZJ "The front of his Jeep is facing me now"
Somebody: "Yeah, I guess that's a predicament"
Quote overhead
Thought I saw nosigma at eastern mountain sports but it turns out the guys xj had been sideswiped
Dunejk13
« Reply #27 on: June 12, 2018, 09:25:52 PM »
Lol my Jeep is at exline as well getting a alignment as well for the same problem lol
unleashd
« Reply #28 on: June 13, 2018, 09:28:53 AM »
I haven't had time to work/get this work done Sad How'd it go with Exline?
KN4MAT
Dunejk13
« Reply #29 on: June 13, 2018, 10:15:07 AM »
Idk yet still there
Pages: 1 [2] Go Up
