March 20, 2019, 05:00:09 PM
Pages: 1 2 3 [4] 5 6 ... 8 Go Down
Author Topic: What did you do to your Jeep today? July 2018  (Read 6190 times)
« Reply #45 on: July 09, 2018, 07:48:30 AM »
With the TJ finished and out of the way.
You know as well as we do that you're never finished, but rather in between work/modifications!   Laughing
« Reply #46 on: July 09, 2018, 08:59:31 AM »
After replacing the MAP sensor in the F250, I went back to the Scrambler and rotated the tires. Dumb bad ball joint makes the driver front tire wear weird, so I am trying to share the pain with the other tires by rotating more regularly until I get to replacing that ball joint.
Let me know when you dig into it. I have an adapter kit for a ball joint press and overhead has a press....
« Reply #47 on: July 09, 2018, 10:41:30 AM »
INDEED Rich!  Cheers I already noticed that it will need a left front u-joint in the future. I was just reluctant to do it with all the other stuff I had done. One cap looks like it's lost lube and is on it's way out. Up on it's list with the to do before winter: New heater core, new heater controls, and two tires and a wheel alignment again.
JEEPIN J
Richmond, VA
« Reply #48 on: July 09, 2018, 10:55:06 AM »
Drove it out to New Baltimore and got it inspected before I haul it down to Richmond...good for another year. Only a few years left til antique tags.
97 TJ 35s & the like
Build on NVJA
Build on JF
tomjones20194
« Reply #49 on: July 09, 2018, 06:40:40 PM »
Trying to track down and stop an annoying oil leak. Does not spot the floor - leaks just enough oil to weep down the block and coat the front of the transmission pan. Replaced valve cover gaskets - no dice. Just replaced upper oil pan seal. Not it. No oil on torque converter so I think the rear main seal is good. Looks to be coming from below heads. No coolant in the oil though so not sure that would be it - any suggestions?  2008 JKUR.
1979 CJ-5 Renegade Levi Edition (360 V8)
2008 Wrangler Unlimited Rubicon
« Reply #50 on: July 09, 2018, 07:28:40 PM »
Dribbles got her first taste of some dirt. Ran her down Peters Mill and nothing fell off! Didn't bother to disconnect or air down as I wanted to slap it around a bit. As many know, that trail and others like it with those Little Rock's and a slightly quicker pace will make any weakness rear their heads. So far so good.....now to do more upgrade work.
« Reply #51 on: July 12, 2018, 05:52:58 AM »
Recently installed the Savvy steering box skid and the EMP radiator guard on the TJ.  Also cleaned up everything after the 3 day mud fest at Rausch!
Dynamic
« Reply #52 on: July 12, 2018, 08:59:35 AM »
Passed Inspection  Banana Dance
2011 JKU Rubicon Project "Serenity" -> SOLD
2017 JKU Rubicon Recon Serenity 2.0
Major Ho
« Reply #53 on: July 12, 2018, 09:56:37 PM »
Over the course of the past few weekends and culminating the past few days I installed just the Clayton rear Long Arms and cleaned up my rusty factory gas skid. I flap disc/grinded it down and slathered the skid in two coats of POR15. Pretty pleased with the candy coating shell.
https://www.flickr.com/photos/28493141@N07/albums/72157669074249127
Rear driver control arm mount was steadily getting more ovaled on the frame side, I already attempted to fix the more outward control arm mount hole years ago.
cmason164
« Reply #54 on: July 13, 2018, 05:06:44 AM »
Tom,
Check the oil cooler/filter adapter housing..
Sent from my 2PZC5 using Tapatalk
« Reply #55 on: July 13, 2018, 06:18:26 PM »
I need to get bolts. I somehow did not have any the right size. The zip ties work for now.
« Reply #56 on: July 13, 2018, 06:34:24 PM »
Oh,  and on the Scrambler, I replaced the neg battery cable due to the clamp on the old one breaking. POS metal.
Does it count that I used the JKU to go to the DMV and then the parts store to get the cable?  I did something to all of them. Sharing the love.
BuckeyeNative
« Reply #57 on: July 14, 2018, 06:00:18 PM »
I signed it up for the VA4WDA trail run in September.
2006 Jeep LJ with a few modifications
« Reply #58 on: July 14, 2018, 06:50:15 PM »
Could not do it on my phone. Back home now and trying but it won’t add to my cart. Hope it is not sold out. Finding out now ....
« Reply #59 on: July 14, 2018, 07:06:10 PM »
As of noon they sent an email saying there was 30 spots left.
Pages: 1 2 3 [4] 5 6 ... 8 Go Up
