March 20, 2019, 04:33:51 PM
Pages: 1 [2] Go Down
Author Topic: Gear Ratio for 35 tires and a 3.5 lift  (Read 1221 times)
Redleg
« Reply #15 on: July 12, 2018, 01:31:04 PM »
If you are gonna wheel go 4.88.  If not, stick to 4.56 got the mileage.
Bill
President - Black Goat Off-Road Club
2016 JKU Sahara  (mine)
2002 TJ Sport (mine too, but I let my son drive it)
Onyx Dragon
« Reply #16 on: July 12, 2018, 04:22:10 PM »
I'm looking at a possible lift and tires for mine (3.5" and 37" tires).  These ratios seem pretty high for a Jeep that will be driven a lot too.  Is there a good compromise gear to use for it, like in the mid 3.##'s?
Bill Staples
1999 XJ
2018 JL Unlimited
jdavis2nd
Club Member at Large
« Reply #17 on: July 13, 2018, 08:43:39 AM »
I've tried really hard not to chime in on this thread because it's always a debate between 4.56 and 4.88 for 35's and really its just everyone's opinion when it comes down to those two ratios. Here is my opinion having run 34s and 37s with 4.88s in my 2014 DD; for 35s if you rarely wheel go with 4.56 otherwise go with 4.88 (I would still go with 4.88s if I didn't wheel).
You are talking about 37s...You want 4.88s! Hell, I kick myself for not doing 5.13s (which I plan do this winter).
« Reply #18 on: July 13, 2018, 10:48:15 AM »
You want minimum 4.56 gears for 37s, probably 4.88-5.13
VAJK456
« Reply #19 on: July 13, 2018, 05:30:55 PM »
Yeah for 37's you definitely want to go with 4.88s or 5.13s. You could get by with 4.56s but if you're going to regear you may as well go with the higher gears. Any gears starting with "3" are out of the question IMO
Onyx Dragon
« Reply #20 on: July 14, 2018, 07:32:26 AM »
So 2.5" and 35s it is then.
Bill Staples
1999 XJ
2018 JL Unlimited
offroadPOSER
« Reply #21 on: July 14, 2018, 12:16:29 PM »
Thanks for the advice guys. Sounds like preference for the most part. I likely will be doing little wheeling.
Pages: 1 [2] Go Up
