February 19, 2019, 11:48:26 PM
Pages: 1 2 [3] 4 5 ... 7 Go Down
Author Topic: What did you do to your Jeep today? - October 2018  (Read 4186 times)
Iowa
AKA: Supercop
« Reply #30 on: October 09, 2018, 03:13:10 AM »
I taught my oldest how to do an oil change on the GMC and the XJ.  Did more trimming on the front fenders to clear the Rubicon take-offs.
PS: Holy crap!  I can finally access my account again! Banana Dance
Sent from my iPhone 7 Batman Ed....
Onyx Dragon
« Reply #31 on: October 09, 2018, 06:39:17 AM »
The black trim is a lot nicer looking.  Mine is all paint matched, and I can't stand it.
Bill Staples
1999 XJ
2018 JL Unlimited
« Reply #32 on: October 09, 2018, 08:26:05 AM »
Yesterday I washed and "conditioned" the soft top and washed the jeep which really just exposed how badly the hood needs to be repainted, lol.
Iowa
AKA: Supercop
« Reply #33 on: October 09, 2018, 12:49:23 PM »
Agreed.  It’s all fading though.  I need to repaint everything.
« Reply #34 on: October 11, 2018, 09:35:44 AM »
Rotated the tires in my driveway.  What a pain in the A$$.  Also greased everything on the bottom.
X7tristan
« Reply #35 on: October 12, 2018, 10:26:26 AM »
What made it a PIA? I was planning on doing my own driveway tire rotations to save some money.
'18 Silver JLUR
« Reply #36 on: October 12, 2018, 10:30:13 AM »
Not enough jack stands?  I loosen the lugs on all five, lift it on all four corners, play roundabout with all 5, then hand tighten all lugs, drop all four corners and then tighten all down. Takes a little time, but not so much of a PITA. I do need to get 2 more taller jack stands. I have four that are 3 tons and 2 6 tons. 2 more of the 6 ton jacks would make me feel better
« Reply #37 on: October 12, 2018, 10:31:49 AM »
Heavy - I'm getting old.  Jacking it all up with jack stands, dragging the jack around.  Lifting them at 90lbs to line up the studs.  Taking the stands back out, dragging it all back to the garage again.  Simple, just tiring (and it was hot and humid at the time).
Edit:  My driveway is angled also so it has to be chocked and moved around as I go.
« Last Edit: October 12, 2018, 10:34:22 AM by RFH_98TJ »
« Reply #38 on: October 12, 2018, 10:37:11 AM »
I hear you. Especially about the weight. And a sloped driveway?  Heck no. I would find a parking lot or the street at the base of my driveway.
« Reply #39 on: October 13, 2018, 03:21:19 PM »
Finally reinstalled my front driveshaft after getting more u joints after Rausch Creek broke three of them.
Oh and took a spin around the neighborhood  in the 3a
https://drive.google.com/open?id=1AsGtMjyd60GLTDBVzDkcV-40h8lk5nZ9
« Reply #40 on: October 13, 2018, 10:26:01 PM »
Emptied out the Jeep to prepare for dropping it off the lift and wheels/tire swap next week. Wife isn't happy about all the camping gear in the living room.  Wasn't Me
« Reply #41 on: October 14, 2018, 12:25:31 PM »
Sad day. Put the hard top back on
JC123
« Reply #42 on: October 14, 2018, 02:07:07 PM »
replaced the transmission pan gasket and filter (#4 on the list). Not hard but sure was messy. I was surprised at how many holes were were threaded to accept the filter torx screws. it took me longer than I'd like to admit to figure out which were the correct ones. I was glad to be able to do it without having to remove the skid plate.
1. replace a/c compressor, dryer and a/c liquid line. evacuate and recharge system.
2. replace radiator and thermostat (flush cooling system)
3. replace drive belt, tensioner & idler pulley
4. replace transmission pan gasket & filter
5. replace valve cover gasket
6. replace tie rod ends, drag links, and sway bar links (requires sub alignment)
7. replace rear shocks
8. replace two downstream oxygen sensors
« Reply #43 on: October 14, 2018, 08:13:56 PM »
Yesterday installed front bump stops, Rockhard engine skid, and diagnosed and corrected why the damn thing wouldn’t start. Today confirmed my heater core has a leak.
« Reply #44 on: October 15, 2018, 09:26:29 PM »
Installed heater core, thermostat, flushed and replaced all the coolant. Tomorrow I'll replace the coolant temp sensor. I've had enough for one day.
Pages: 1 2 [3] 4 5 ... 7 Go Up
