January 21, 2019, 01:09:58 PM
Author Topic: Seriously Chrysler?  (Read 446 times)
« on: November 07, 2018, 06:15:52 PM »
Tranny drain plug right over top of an exhaust crossover that you have to custom build a tool to access. Moron engineering at its best.
« Reply #1 on: November 07, 2018, 06:22:24 PM »
At least there is a drain plug. So they are moving forward.
Sent from my SM-N950U using Tapatalk
1969 Jeepster Commando in work
2018 JKU Golden Eagle,Teraflex leveling kit, EVO oil and trans skid
« Reply #2 on: November 07, 2018, 06:34:48 PM »
True...
« Reply #3 on: November 08, 2018, 08:29:08 AM »
 Laughing Laughing
AngryEchoSix
Busted Knuckle Garage Expert
« Reply #4 on: November 08, 2018, 09:04:50 AM »
Yup...huge PITA....especially now that you have old tranny fluid all over that crossover pipe.
2014 JK Unlimited Rubicon X
« Reply #5 on: November 08, 2018, 11:36:27 AM »
Yeah - looks like they welded a little shield on top of the pipe but that just further reduces the distance between the pipe and the plug such that you have to make your own tool to get in there. I took an old 17mm Allen socket and cut it down to about 3/4” with a cutoff wheel so that I could get it in there and turn it with a wrench. Takes warming the tranny fluid up before draining off the table - it has to be stone cold when you drain or you will burn the heck out of yourself
« Reply #6 on: November 08, 2018, 05:25:23 PM »
You can bet that FCA’s shop handbook calls for an extra billable hour of labor to service the trans since they “have to drop the exhaust” to complete the job!
« Reply #7 on: November 08, 2018, 06:55:45 PM »
Yeah I wonder how far up that drives the price. All the more reason to learn to DIY. I’ll bet they charge over $300 by the time the smoke clears. I’m in about $45 including the fluid and the tool I hacked up
