August 25, 2019, 11:25:00 AM
Author Topic: Soft top questions  (Read 168 times)
LuckyAce1974
« on: June 25, 2019, 06:25:14 AM »
Looking for a used 4 door Wrangler
Is there any way to tell if a top is a cheap replacement or a high quality?
Any areas of the top to look at for wear or problems?
Can a soft top Jeep be sent through an automated car wash?
Can a hard top Jeep be sent through an automated car wash?
« Reply #1 on: June 25, 2019, 06:34:06 AM »
For car washes, touchless are pretty much fine for any vehicle.  They just spray water and chemicals.  Regardless, I never take my soft top TJ to one, as water winds up spraying inside from a few small openings from the different angled nozzles leaving soap behind.  If you have a soft top, avoid the spinning brush type washes as these will put many fine scratches in your windows and start making them look bad after a while.  You can't just buff them out.  As for the hula type washes, those aren't as bad on soft tops, but they are still adding a few scratches to your windows as they can drag loose grit across the windows.
