November 16, 2019, 11:55:39 PM
Pages: [1] 2 3 4 Go Down
Author Topic: What did you do to your Jeep today? - September 2019  (Read 3524 times)
« on: September 01, 2019, 09:10:42 AM »
Tested out the new transmission cooler, temperature gauge and Antirock adjustments at Chaos Offroad Park yesterday.
http://novajeepers.net/index.php?topic=17688.msg323874#msg323874
« Last Edit: September 01, 2019, 09:27:00 AM by Runner »
majestek12
« Reply #1 on: September 01, 2019, 10:14:43 AM »
Replace rear drums and break shoes YJ
It was challenging
I learned the on the shoe adjustable, the rear driver side was reversed thread and the passenger side is regular thread.
You need to keep an eye on that.
The whole thing can be a puzzle if you didnít take photos.
Good job getting the front and rear shoes on the correct side. Lots of guys look over this.
Another trick, besides taking pictures, is to pull both drums but only work on the brake hardware of one side at a time. This way if you have any questions on how things go back together you can always reference the other side. Not a small undertaking, if this was your first time great job!
« Reply #2 on: September 01, 2019, 10:47:37 AM »
It was challenging
That is what I do every time. Nice to have the reference, even if it is a mirror image.
« Reply #3 on: September 01, 2019, 10:50:02 AM »
After fighting with the Scrambler for a week, I got it running again. I suspect the timing chain jumped a tooth or so. Found the compression stroke and set it all up and noticed that the timing mark was off a bit to the advanced side. So I am sure something is wrong and it will happen again. But for now it runs and will get me to the commuter lot. Maybe the chain is stretched. Will look i to that another day.
« Reply #4 on: September 02, 2019, 10:41:09 AM »
And new day,new problems. Even though I was getting the Jeep started, i think the timing chain is still off a tooth or two and making it difficult to start. Well, as a result, I went on a test drive and came back home. Turned it off and went to turn it over again. The starter literally blew into pieces. It also chewed off a few teeth on the flywheel. So it is down for a while. A lot of work is needed now. Craptastic. Sigh.
smileyT
TIP your Bartender and Waitstaff!
« Reply #5 on: September 02, 2019, 11:28:38 AM »
New Barnes 4wd tie rod. Alignment tomorrow morning.
T
2000 TJ Sold
1996 Grand Cherokee lift, control arms, 2001 wj leather seats family owned since new!
2016 Jku sport 2.5 lift, Geo brackets, front, rear bumpers, winch w/ synthetic line, 37 BFG AT, aluminum paint matched fenders inner fenders, bartact seat covers, rear seat capt chair conversion, etc
jwilson2598
Webmaster
« Reply #6 on: September 02, 2019, 08:36:37 PM »
Productive morning in the garage:
Removed upper rear shocks bolts and put the anti seize on them I forgot a week ago when doing the lift (oops)
Replaced the foam upper rear bump stop that broke off last weekend during the lift install
Changed gear oil in front and rear axles
Replaced rusty locking long nuts
Upgraded fog lights to the 05-06 versions
Replaced a JKU rear bumper for a friend
Jeff
2013 Unlimited Sahara, Gecko Green
AEV 2.5" lift, front/rear bumpers, hood, Argent Pintler wheels, 315/70/17 Duratracs.
« Reply #7 on: September 06, 2019, 02:13:57 PM »
Removed the top and doors from the JKU for the weekend. Gears will be installed at the end of the month. 4.56's
1969 Jeepster Commando 2in lift, always in work
2018 JKU Golden Eagle, Rancho 2in progressive springs
jdavis2nd
Club Member at Large
« Reply #8 on: September 06, 2019, 05:38:50 PM »
Nice!
Sent from my SM-G973U using Tapatalk
« Reply #9 on: September 06, 2019, 05:42:44 PM »
Nice!
I blame you and Stephen. Running blues and blacks is gonna make me go broke.  I might even put a Trutrac in it too.  LOL!
Sent from my mobile device
« Reply #10 on: September 06, 2019, 06:52:04 PM »
Nice!
I humbly thank you again. And I knew that jku could do it.
drekalots
« Reply #11 on: September 07, 2019, 01:44:06 PM »
While greasing the front end I figured out why my Jeep has been rolling in the corners... need to go buy a few of those pins now.
« Last Edit: September 07, 2019, 01:51:33 PM by drekalots »
2015 JKU-S
« Reply #12 on: September 08, 2019, 08:11:58 AM »
Put a deposit down on a new power plant for it. should have it taking up space in my garage by the weekend.
« Reply #13 on: September 08, 2019, 12:51:49 PM »
I hope it was dirt cheap to merit messing with a 4.0.
« Reply #14 on: September 08, 2019, 02:38:02 PM »
You are the first to say anything not so nice about the swap. And yes, I thought it was priced well enough. I will need to get a wiring harness though.
Pages: [1] 2 3 4 Go Up
