November 16, 2019, 11:30:42 PM
Pages: 1 [2] 3 4 Go Down
Author Topic: What did you do to your Jeep today? - September 2019  (Read 3522 times)
« Reply #15 on: September 09, 2019, 06:29:18 AM »
I this the one out of the Scrambler?  Are you going from a 4.2 to 4.0?  What's the difference?  Will your replacement just bolt up or will you need adapters?  Did I read you also have an Atlas to go in?
« Reply #16 on: September 09, 2019, 06:34:57 AM »
The 4.2 will come out. This 4.0 will go in. It has the aw4 (with overdrive) and the t-case, but I won’t be using the t case. While it is not an atlas, I did just install a dana 300 with 4-1 and twins sticks. So I want to keep that in the Scrambler. So now I need to find some important things like a wiring harness and ecu for this 4.0. Supposedly it is an easy swap. We will see. I have a lot to read so that I am prepared.
« Reply #17 on: September 09, 2019, 06:43:13 AM »
Scott (Crazyskier92) may have an ECU and the wiring for it since he parts out a lot of TJs.
« Reply #18 on: September 09, 2019, 07:07:06 AM »
I was thinking of reaching out to Scott. Thanks
« Reply #19 on: September 09, 2019, 07:28:36 AM »
Put the Sniper stuff on it and let it run it.
94JeepYJ
« Reply #20 on: September 09, 2019, 07:36:29 AM »
You planning to run the the auto trans?  I've got a 98 AT ECU laying around that you are welcome to.  Many years ago I swapped a 99 4.0 into my CJ-7 and it was a huge improvement over the carbed 4.2.  You won't be disappointed.
94 Jeep YJ 4.0L AX-15 4.10 gears
« Reply #21 on: September 09, 2019, 07:38:05 AM »
Um. Yes. I would love to have the ECU. Thanks.
94JeepYJ
« Reply #22 on: September 09, 2019, 07:49:14 AM »
It is in Warrenton off 29 close to Effees or I can bring it with me to Herndon when I go to work.  I still have the motor and wiring harness if you are considering adapting it to your current harness and want to look at it for ideas.
PM me and we can set something up.
« Reply #23 on: September 09, 2019, 07:56:29 AM »
I would be interested in the harness as well. I will PM you. Thanks.
94JeepYJ
« Reply #24 on: September 09, 2019, 08:18:20 AM »
I've been a little busy...
A couple weekends ago I upgraded to a Durango Power Steering box.  Last weekend I installed Poison Spyder hood louvers.  This weekend LED headlights and a dual coolant switch in prep for a taurus fan.
wbsjp
« Reply #25 on: September 09, 2019, 02:56:23 PM »
Did you get the TCU for the trans ? Need that too and it must match the year of the trans.
Wayne
  AARP,NAXJA,NRA Endowment member
"the cost of Freedom isn,t Free"
« Reply #26 on: September 09, 2019, 10:39:23 PM »
Had new brakes put on.  Watched my friend Willie snap a bolt on the caliper housing!  Ugh!  Thank goodness they had some spares on hand!
Big Mike - 2012 JKU Crush, 2.5" Teraflex Lift with Shocks, JKS Quick Discos, RockHard4x4 Skids and Evap Relocation Bracket, JCR Crusader Bumpers (mid-width front, mid-width rear), Teraflex HD hinge tire carrier, SmittyBilt h2o winch, 16x8 ATX wheels with 315-75-16 General Grabber AT2's.
Skipperart
« Reply #27 on: September 10, 2019, 12:46:42 PM »
Fyi
Code: 118792850111416878
Thank You for Being a RockAuto Customer!
Using your discount code is easy! Enter your discount code in the 'How Did You Hear About Us?' box without any other numbers or characters for an additional 5% savings. Discounts cannot be applied once an order is marked as shipped.
Your code expires on November 10, 2019, so do not wait!
SHOP NOW
Share Your Code!
There is no limit on order size or number of orders - use your code on your next order, and share it with your friends and fami
drekalots
« Reply #28 on: September 10, 2019, 06:05:51 PM »
Stared at it wondering how in the hell the track bar bolt and sway bar disconnect pin went MIA and when it happened.  Dunno?
2015 JKU-S
« Reply #29 on: September 10, 2019, 07:13:38 PM »
Fixed the damage from wheeling it a little harder at Chaos on Labor Day weekend.
 - replaced 2 broken grease fittings on the drive shafts
 - replaced torn front driveshaft grease collar
 - replaced busted front yoke
 - ground and painted all rock damage on frame, control arm brackets, and differentials
 - greased all steering and driveshaft fittings
Still on the list to fix, a steering problem. Turning the 35" tires and beadlocks on the rocks is inconsistent and sometimes problematic.
Pages: 1 [2] 3 4 Go Up
