November 16, 2019, 03:51:09 PM
Pages: 1 2 [3] 4 Go Down
Author Topic: What did you do to your Jeep today? - September 2019  (Read 3509 times)
drekalots
« Reply #30 on: September 11, 2019, 01:22:49 PM »
Got the new trackbar bolts in the mail. Should I use loctite even though I have nylock nuts?
2015 JKU-S
« Reply #31 on: September 11, 2019, 01:29:27 PM »
Personally, I'd use a flange nut.  Nylocks have less steel contact (because they have the insert) with the bolt so they offer less griping power most of the time.  Locktite would not really be necessary, but could be used on a flanged bolt.
Skipperart
« Reply #32 on: September 11, 2019, 04:51:18 PM »
I've been a little busy...
A couple weekends ago I upgraded to a Durango Power Steering box.  Last weekend I installed Poison Spyder hood louvers.  This weekend LED headlights and a dual coolant switch in prep for a taurus fan.
What does the taurus fan do?
Tt
« Reply #33 on: September 11, 2019, 05:09:43 PM »
Tt
I switched from a clutched mechanical dan to the taurus electrical fan a couple of years ago. What it did for me was give me room. My mechanical fan was too close to the radiator and bounced into it one day and sprang a coolant leak. I gained about 2 inches more room bu installing the twin fan taurus set up.
94JeepYJ
« Reply #34 on: September 11, 2019, 07:46:05 PM »
The last trail ride I went on the coolant temps kept creeping up while we were going slow or sitting still.  The louvers will hopefully help reduce the overall under hood temps a little.  The electric fan will automatically kick into high when the temps rise.  Preventing me from getting worried and turning the heat on in 100 degree weather. 😎
I probably could have just replaced the fan clutch, but for around 50 bucks I was able to purchase everything I need from salvage yards to do the swap.
94 Jeep YJ 4.0L AX-15 4.10 gears
drekalots
« Reply #35 on: September 12, 2019, 03:42:37 PM »
Replaced the upper quick disconnect pin and trackbar bolts. Rides much nicer now. lol.
2015 JKU-S
« Reply #36 on: September 13, 2019, 06:34:43 PM »
Added a chuck to my front bumper for on-board air without having to open the hood:
Not a bad mod for $37. No leaks and works great.
Sarkis
Freebird - 2000 TJ SE
UCF Tummy Tuck
« Reply #37 on: September 15, 2019, 09:07:07 PM »
Here marks another round of car taxes down and another year of renting my vehicles from the state of Virginia...
drekalots
« Reply #38 on: September 16, 2019, 05:02:28 AM »
I just did that in WV. I hate taxes.
2015 JKU-S
« Reply #39 on: September 16, 2019, 12:57:23 PM »
Dont forget if you paid VA state income taxes in 2018 you will get an addl refund check in Oct from the state. Mine is around $100.
Still not even with the Feds since I had over $10K State and local taxes and I couldnt deduct them all on my return. Will be in the same mess this year unless Congress changes the law for 2019.
I would rather eat the couple hundred bucks and listen to folks in NY, NJ, MA, CA, and MD scream about the taxes they cant deduct this year.  We see since Congress still needs to pass a continuing funding resolution or a budget for FY 2020. They arent close and House Dems keep grandstanding.  I could use a few days off in Oct especially since my part of DOD is reorganizing starting Oct 1. My senior leadership will have fun doing this.
I pay my personal property taxes to FFX Cty Marxists online the day before its due. Thank God the county doesnt tax herding dogs as property or I would pay more for my dog than I do my Jeep by triple or more.
« Reply #40 on: September 19, 2019, 07:15:46 PM »
I had a weird creak coming from the transmission when I pushed the clutch on or near the top when I let off.  I did a little internet research and spoke with a good friend of mine from back home. I determined it is the rod from the slave cylinder.  I pulled it out, put a little grease on it and put it back in, problem solved.  Maybe took 20 mins. Itís nice when repairs are quick and painless.   Cool
« Reply #41 on: September 23, 2019, 08:48:59 AM »
Dropped the JK off to get the gears swapped out. Having ORI install 4.56ís
Sent from my mobile device
1969 Jeepster Commando 2in lift, always in work
2018 JKU Golden Eagle, Rancho 2in progressive springs
« Reply #42 on: September 23, 2019, 04:36:28 PM »
Dropped the TJ off at Matchless Auto Body in Vienna in hopes that they can yoink the driver's rocker panel back out into place.
« Reply #43 on: September 23, 2019, 05:56:22 PM »
Added a provent system to the diesel KJ as well as changed my engine tune from a stage 1 to a green tune which focuses less on added horsepower and more on increasing MPGs.
« Reply #44 on: September 25, 2019, 05:05:09 PM »
Took the rolled Jeep Iíve been working on to work with me to inspect it and have a windshield put in there instead of at home. Turned out well for what I started with.
Pages: 1 2 [3] 4 Go Up
