December 09, 2019, 09:38:01 PM
Linked Events
  • Monthly Trail ride : January 18, 2020 - January 19, 2020
Author Topic: January Winter trail ride at AoAA January 18th - 19th.  (Read 1406 times)
Member 2019 VA4WD
« on: October 18, 2019, 06:24:31 AM »
First of what i hope to be a monthly event.
Planning on a Green/blue trail ride at AoAA off road park in PA.  http://www.aoaatrails.com/
Initial plan  is to run a day and a half and explore the park. Being January  the weather wcan be cold, freezing and or snowing so plan accordingly.
Idea is to meet at the park when they open and  wheel to  closing.
Minimum  of three rigs for the trail ride.
Lead R3
1)Irish_Wake
2)JP-XPLR
3)
4)
5)
6)
7)
Cool
9)
Tail.
Wait list
« Last Edit: November 21, 2019, 07:37:15 AM by R3 »
Nacho
Member 2019 VA4WD/BRC
« Reply #1 on: October 18, 2019, 12:02:14 PM »
I've never been but it sounds cool... Is there a date?
Sent from my SM-G965U using Tapatalk
Jeepin_Donnie
Club Vice President
« Reply #2 on: October 18, 2019, 01:18:07 PM »
Hey Scott,
The ride is on January 18th - 19th.  It's linked from the main calendar at the top under the NVJA banner.  Can you see the dates above Rob's original post?
Mods, they never end.  My rig needs a sponsor!  Smile
Nacho
« Reply #3 on: October 18, 2019, 02:54:33 PM »
Hey Scott,
Now I do....I could not see it using the app...imagine that.   Thumbs Up
Jeepin_Donnie
Club Vice President
« Reply #4 on: October 18, 2019, 04:19:16 PM »
Hey Scott,
Haha, ok!  Just wanted to make sure you could see the "Linked Event" dates.  Thanks!
Nacho
« Reply #5 on: October 18, 2019, 04:23:15 PM »
Thanks
Irish_Wake
Arlington, VA
« Reply #6 on: October 27, 2019, 08:23:51 PM »
I'd like to toss my hat in the ring for this.  Assuming something doesn't go horribly horribly wrong with my lift and axle swaps in the coming months.  Or that I run out of money Redfaced
-Patrick
2000 TJ Sport
Rubicon D44 Rear with factory locker | Open D30 front | 4.10
Rubicon 241OR Rocktrac Transfer case
2.5" OME Springs & Shocks | JKS 1.25" Body lift
33x12.5r15 Falken Wildpeak M/T01
Passe-Partout
« Reply #7 on: November 09, 2019, 01:55:50 PM »
Donnie - Sorry for not getting this out to you sooner. I want to thank you so much for organizing this event! We all had a great time even though I had the problem with shifting into 4wd Lo. I especially want to you for your kindly escorting me off the trail. Knowing that you were there "just in case" was a great comfort. The understanding and support you provided to us really demonstrates the "leave no one behind" credo of the community and especially NOVA Jeepers.
Diagnosis of this Wrangler JK problem: The $9 orange plastic clip (Mopar #68018106AA "Gear Shift Cable Retainer Clip") that secures the outer sheath of the transfer case cable broke off under the vehicle. This clip secures the outer sheath of shift cable to a bracket that is secured to the transfer case. The purpose of this clip is to hold the outer sheath in a fixed position so that the inner cable can extend or contract as the transfer case shift lever is moved from 2 hi to N, 4 hi, or 4 lo. This part is easily fixed on the trail without the need of any tools by just snapping the new clip (the old typically falls out when it breaks) onto the outer sheath and then snapping the clip into the bracket attached to the transfer case. I ordered some additional ones to have on hand in case it fails again (or someone else experiences this problem while wheeling with me).
I should also mention that there is another pair of white plastic clips (Mopar #68064273AB "Transfer Case Shifter Bushing") that attach the transfer case shift cables to the lower end of the in-vehicle transfer case shift lever on one end and the transfer case shift lever under the vehicle on the other. These parts are around $3 each and are also prone to failure. The symptoms are the same: inability to shift the transfer case and a floppy shift lever. I also bought a pair of these as spares just in case.
One can only wonder why Jeep would use cheap plastic clips that are prone to failure that serve such a critical role - potentially stranding someone in a remote off-road location far from help.
I also want to report an interesting and frustrating problem with having Jeep cover the failure of the transfer case gear shift cable retainer clip: They were refusing to cover this repair under my manufacturer's extended warranty since "the defective part must be returned for warranty coverage". Since this part fell out of the retaining bracket when it broke they were refusing to cover the repair. I was ultimately able to get Jeep to cover the repair after many discussions with the dealer and Jeep. FYI - there are no such exclusions in the extended warranty contract.
Lesson reinforced: always wheel with someone else, or better yet, with a group (e.g. NOVA Jeepers) that can provide assistance in case of mechanical failure, getting stuck, or injury!
2014 "Overland"
AEV 2.5" Lift
M/T Baja MTZ 33" on M/T Classic Lock Wheels
JKS Discos
Smittybilt XRC MOD Front & XRC Gen2 Rear Bumpers
Smittybilt X2O 12K Comp Winch
sPod SE Bluetooth
Cobra 75
Truck Lite & JW Speaker LED fog lights
Baja Designs LED Lights
Rugged Ridge Tube Doors & Rock Sliders
Irish_Wake
Arlington, VA
« Reply #8 on: November 18, 2019, 02:13:45 PM »
I just noticed this is listed as two days on the calendar.  Are we planning an overnight trip?  I might need to beef up my winter camping gear more than my Jeep gear  Freezing your buns off
-Patrick
2000 TJ Sport
Member 2019 VA4WD
« Reply #9 on: November 19, 2019, 07:41:26 AM »
Listed as a two day run yes. The usual suspects  come up Friday night  and  hit the trails all day Saturday and  a half day Sunday.  I tend to camp at the  Hampton Inn, others prefer the camping at Comfort inn...  both offer excellent camp sites  ROTFLMAO  with  facilities.  If you are a bit more manly yes Rausch offers  primitive camping on the grounds. Igloos are optional. Freezing your buns off
Irish_Wake
Arlington, VA
« Reply #10 on: November 19, 2019, 02:03:52 PM »
Hahaha!  I hear the facilities are best in class.  I'll need to check my schedule and costs.  Full day of wheeling without needing to worry about the drive back sounds like a blast.  Despite 4 years in the Great Lakes region, as an Arizona transplant winter camping does not sound like my cup of tea.  Or hot chocolate.  Or whatever I'll be drinking to keep warm.
-Patrick
2000 TJ Sport
Member 2019 VA4WD
« Reply #11 on: November 20, 2019, 06:48:52 AM »
I hear ya brother.
Off road consulting is the code to get a discount from either hotel. Hampton is a bit more $$ both are  basically a few minutes from Rausch Creek. Weather can be cold and snowy  or warm and muddy that time of year.  We will assess the conditions and  pick trails accordingly.
Irish_Wake
Arlington, VA
« Reply #12 on: November 20, 2019, 09:00:00 AM »
I hear ya brother.
Are we running Rausch or AOAA?  Are they close enough to do both?  New to the area and I'm game to explore either.
-Patrick
2000 TJ Sport
Member 2019 VA4WD
« Reply #13 on: November 20, 2019, 03:29:18 PM »
 Pat Pat So I  usually run to Rausch..... forgot that the title was AoAA..... Duh
So  I do not know if there is camping at AOAA or if lodging is closer to AOAA than Pine Grove. But yes the intent was to hit AOAA  for some winter fun.
Sorry having a senior moment.... Pat Pat
« Reply #14 on: November 20, 2019, 03:46:29 PM »
there is apparently a fantastic cabin camping site with multiple cabins that support gooseneck trailers about halfway between the two. I don't know the name of the place as I haven't been there myself, but I can get the info if you'd like.
