August 23, 2019, 05:47:37 PM
Author Topic: ORI Giveaway - K&N Intake (Oct 2010)  (Read 2054 times)
« on: March 29, 2012, 10:14:04 PM »
Quote from: DubbyDoo
KNN FIPK Gen 2 kit for the Cherokee
Tools needed for install:
   Flat head screwdriver
   7/16 wrench
   3/8 ratchet
   12 inch 3/8 extension
   3/8 1/2in socket
   3/8 7/16 socket
1. Remove the two plastic clamps with the flat head screwdriver on the stock intake pipe going from the throttle body to the intake box. Remove the intake pipe.
2.Remove the crankcase vent line and the evap canister vent line from the top of the intake box then remove the upper intake assembly.
3.Remove the two bolts and one nut with the ratchet, extension, and socket and remove the lower intake box.
4.Install the weather stripping to the heat shield trimming away the excess.
5. Using the L bracket and hardware that is supplied install the bracket to the head shield.
6. Install the heat shield to your fender well using the supplied hardware and some that you removed earlier.
7. Install the silicone hose coupler to the bottom on the KNN intake pipe as well as the KNN filter to the other end, tighten the clamps.
8. Install the intake to the throttle body and tighten the last clamp.
9. Using the supplied silicone hoses connect the crankcase vent and evap canister back to the intake pipe.
10. Now enjoy the wonderfull hissing noises and extra power your cherokee makes! Hp gains of 7HP Tq gains of 8FTLBS
stuff you will no longer need
